Now that my 1102 is working as it should I can turn my attention to the cosmetics. The lid needs a polish, but the main issue is that the "woodgrain" (which actually appears to be a thin veneer of plastic?) along the sides is coming off and needs re-gluing, but worse still the strip along the front is missing.
Is there a source of replacement veneer?
For my BM 2400 I made the left side panel (missing when bought) out of pressed wood board 1/8" and thin veneer. Glued on with small pieces of double sided tape. Here you will find veneer, iron on, glue on etc.etc.
The wood on your Beogram is actually real wood glued onto a plastic base.The plastic base itself is a different color according to the wood sort.What woodsort is your Beogram (oak, teak or palisander) ?
