When I turn on my BV7-40 mk2, it shows the electronic curtains opening when i chose "tv" or "DVD".
I have my Apple TV3 connected via DVI, and it is set to the DTV option. When I push DTV the picture just shows up, there are no electronic curtains opening. Am I missing a setting, or is it just not possible?
Leosgonewild: Am I missing a setting, or is it just not possible?
Just leave your ATV 'alive' - setting is 'sleep after - never'.
Power consumpion is minor - 0.8 watts:
http://apple.stackexchange.com/questions/82422/how-much-power-does-apple-tv-use-on-standby
StUrrock:on a mk2 there are no curtains on HD sources
OK - thanks for that information.
That is the real explanation.
I don´t have electronic curtains on DVD either.
Is there an upgrade chip I can get to get electronic curtains on hd sources?
