Beogram 1202 Manual Function
This post has 7 Replies | 0 Followers
Ben_S
UK
Posts 631
Ben_S Posted: Fri, Aug 29 2014 7:28 PM
Attempted to use my Beogram 1202 this evening and found that the manual operation would not engage at all.
The automatic function worked fine and the needle dropped accordingly on both a 33 and 45 but when I turn the wheel to select manual there is absolutely nothing.
Any ideas?
Thanks!
Søren Mexico
Mexico City
Posts 6,411
Probably the switch you see in the pic, lower left corner, clean and adjust, and check that the arm from the speed selector operates the switch in "manual"
Ben_S
UK
Posts 631
Ben_S replied on Sat, Aug 30 2014 8:47 AM
Many thanks Soren, I will try this later today and post results!
ben
Ben_S
UK
Posts 631
Ben_S replied on Sat, Aug 30 2014 11:06 AM
Sorted! It was the switch, many thanks Soren, playing beautifully now!
Søren Mexico
Mexico City
Posts 6,411
Your BG looks very good, glad to hear it works, I like the design a lot, fits perfectly to my BM 901. Got my SP 14 repaired by Axel and also got the belt from him.
Ben_S
UK
Posts 631
Ben_S replied on Sat, Aug 30 2014 8:18 PM
Thanks Soren, it is in lovely working order thankfully!
I like the design a lot too, I'm after the matching Beocord 1200 at some point, but recent prices here have been pretty high. I guess they are quite a bit rarer than the Beogram!
Søren Mexico
Mexico City
Posts 6,411
Here you go, or ask Martin (Dillen)
Ben_S
UK
Posts 631
Ben_S replied on Sat, Aug 30 2014 9:27 PM
Sadly getting one back to the UK would be tricky from Denmark, I may speak to Martin!
Page 1 of 1 (8 items) | RSS
