Help appreciated: ML/MCL connected to BV7-32 makes noise after two months
MJBeo
Netherlands
Posts 270
MJBeo Posted: Mon, Sep 1 2014 9:09 PM
Hi Beoworld,
I have an ML/MCL converter attached as a center speaker on my BV7-32 (MK III) with powerlink (4 wire I think, thin), and two CX50 speakers attached to the ML/MCL (both need new foam). I configured the speaker as being a "single Beolab 400". After two months the amplifier started making this familiar low buzz noise when it is switched on - regardless of the volume of the speakers of course. The amplifier made the same noise when I connected it to a different powerlink (in this case MCL2 AV), so thank got it is not the TV, but perhaps it was causing it?
I have replaced the ML/MCL converter with another one, and the noise was gone. My concern is that I have done something wrong in the connection or configuration, and that the new amp will be damaged within two months as well. Is that likely? I changed the configuration to a "double Beolab 400", for a start, but I am not sure what more I can do. Any suggestions on how to prevent this? And can I repair the other ML/MCL?
Thanks!
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
MJBeo
Netherlands
Posts 270
MJBeo replied on Tue, Sep 9 2014 12:24 PM
Guys...? Anyone had this problem?
Page 1 of 1 (2 items) | RSS
