Avant SW Update Available Now
This post has 20 Replies | 4 Followers
Solidsnake
Posts 143
Solidsnake Posted: Wed, Sep 3 2014 1:51 PM
The update is now available.  It actually is a later version than the one that FlatpanelsHD had for their review.
I've installed it but haven't had a chance to check the improvements.  Anyone notice the benefits?
Roger
Norway
Posts 417
Roger replied on Wed, Sep 3 2014 1:56 PM
Great news! Looking forward to a closer look this evening.
Please post any observation you come across.
Roger
Michael
Sweden
Posts 2,578
Michael replied on Wed, Sep 3 2014 1:58 PM
A good idea would be to have a standing thread about the updates for the Avant so it would be easy to get notifications about it - and not clutter up all of BeoWorld with many many threads about the same thing :).
I look forward to trying the update out. I guess this also means updates for the other units on the same platform (V1/BV11)/BSys4).
mr_anders_son
sweden
Posts 1,710
Just bugfixes....
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Millemissen
Flensborg, Denmark
Posts 14,680
My V1 got the update (1.0.7.36015) today.
Haven't noticed anything spectacular so far - apart from support for the BeoRemoteOne.
"Different Improvements and smaller bugfixes - Correction of a problem with a too dark screen" (translated from danish).
No changes to 'auto-muting the screen' with Spotify and music in HomeMedia.
Nothing new (that I could find) in WebMedia.
And no 'NetRadio' No - thumbs down
If you did not already knew that it's a new SW, you would not notice it.
malcolm welborn
canary islands
Posts 188
I have beolab 18 fitted wireless, now when selecting speaker mode in set up it changes a lot quicker, since downloading software to my beovision 11
malcolm
mjmedlo
Posts 922
mjmedlo replied on Wed, Sep 3 2014 5:40 PM
If anyone has a beolink gateway attached press the 'home control' from the list and see if it does anything yet?
Michael
Sweden
Posts 2,578
Michael replied on Wed, Sep 3 2014 6:57 PM
Millemissen:
And no 'NetRadio'
BeoRemote one was already supported
Millemissen
Flensborg, Denmark
Posts 14,680
Michael:
Ups - so really nothing worth mentioning for the V1?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Sep 3 2014 8:43 PM
fixed in Homemedia:
shift in channel spectrum in 5.1 lpcm or flac file is corrected; the central channel is were it should be (as the others)
4.0 & 5.0 surround files are now supported;
 88.2 kHz Flac file is supported
Millemissen
Flensborg, Denmark
Posts 14,680
Carolpa:
fixed in Homemedia:
i wonder if that also goes for audio over HDMI as discussed in this thread:
http://archivedforum2.beoworld.org/forums/t/10944.aspx?PageIndex=3
Michael
Sweden
Posts 2,578
Michael replied on Thu, Sep 4 2014 1:43 AM
The update took almost 20 minutes on my avant and seem to have fixed the problem I had with the light sensor/backlight - but I have to watch it for a few days to be sure.
Not sure but feels like sound and picture are a bit out of sync - but might be me that is tired.
On V1 I noticed update went considerable quicker. It also has DMR now (digital media renderer).
No BeoPlay S8 profiles which I find strange (even if it is BeoLab 14..).
Millemissen
Flensborg, Denmark
Posts 14,680
The V1 already had the DMR update!    Big Smile
Griebel
Posts 416
Griebel replied on Thu, Sep 4 2014 8:36 AM
There is at least one improvement I noticed in Homemedia during audio listening: the cover is no (again!) displayed in high resolution.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Sep 4 2014 11:27 AM
Millemissen:
Carolpa:
fixed in Homemedia:
tried an older Oppo. No sound with a Neil Young DVDA in 176.4 kHz. Sound, but distorted, when playing SACD. Note: input Mch SACD - BV11 displays Input  PCM 2ch.
Roger
Norway
Posts 417
Roger replied on Thu, Sep 4 2014 12:30 PM
@carolpa: I sat the OPPO to do all the decoding and send the processed sound as (multi channel) PCM to the BeoVision. Works great.
Roger
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Sep 4 2014 1:12 PM
Correct Roger!
But BV11 doesn't play 88.2 or 176,4 kHz resolution through hdmi.
When I use the Oppo BRP103 I have sound because the Oppo resamples the signals to 24bit 48 kHz. If I feed the BV11 the same format with an Oppo DV981HD or Oppo BDP83 I get the situation as discribed.
Before the BV11 I had a BS3/BV4 combi. All LPCM formats were reproduced when processed by the Bluray player.
MrBeeh
Posts 7
MrBeeh replied on Thu, Sep 4 2014 4:48 PM
The hikup on netradio is still there, very anoying
Michael
Sweden
Posts 2,578
Michael replied on Thu, Sep 4 2014 5:34 PM
MrBeeh:
What hickups? Do you use the wifi connection? I found that it works very badly and switched to ethernet which works much better. Haven't had problems with radio hickups in the old firmware - but some stations would not work all the time.
MrBeeh
Posts 7
MrBeeh replied on Thu, Sep 4 2014 6:00 PM
I use ethernet to but i have hikups every few minutes. I'm not the only one in the Netherlands. I have no trouble on my Denon receiver but with the Avant it's anoying.
BeoPer
Stockholm
Posts 12
BeoPer replied on Thu, Sep 4 2014 6:32 PM
Same hikup issue for me with ethernet in Sweden.
Page 1 of 1 (21 items) | RSS
