BeoSound 3000 defaults to loud volume on power up
jkhamler
Posts 286
jkhamler Posted: Thu, May 10 2012 12:39 PM
Strange, it's just started doing this - when I turn it on, the volume is always set pretty loud (around 40) so I have to turn it down straight away. Tried powering it off and an again, no good. Has anybody else encountered a similar problem?
Thanks, Jonathan
TomLyons
Posts 30
TomLyons replied on Thu, May 10 2012 1:54 PM
Hi jkhamler.  The default volume is set when you change the settings in the sound menu.  Go back into the menu and set the volume to a comfortable level, then press the OK button.   It should be ok after that
jkhamler
Posts 286
jkhamler replied on Thu, May 10 2012 2:15 PM
Thanks Tom!
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
