Hi everybody.Does any one know, if I could use Beo5 with an old Beosystem 7000, or 4500?And if so, does it support two way communication with it?I couldn't find any information from the Net.
Hi, I'm looking for Beogram 4500 with a good needle.
the Beo5 can replicate any other IR device so you will be able to use it. However, it is not a two-way remote so for that you would need a Beolink 5000 or 7000.
BR
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Ok. Thanks for your advice.So I better start looking at Beolink 7000. It seems to be very rare and expensive, though.But that's life...
