Beovision 7 av switch
Maurice
Posts 108
Maurice Posted: Wed, Sep 10 2014 11:28 PM
Can anyone advise exactly which of the 3 ic in the EEPROM PCB contains info for the pin number on a Mk 3 BV 7 I HAD a fault red STBY only no responce to remote , I obtained another av switch PCB and installed it this gave black / white horizontal fine lines then after a couple mins shut down. I then installed the origional av switch  PCB with the new  EEPROM PCB and it's now working , with the pin screen .... Trouble is I don't have the serial number of the donation tv. I have requested the serial number from the seller but if thats not avail which ic do I transfer to get going?
Regards Maurice
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Sep 11 2014 12:21 AM
I believe you are asking this in good faith, but I guess you understand why that information will not be available (even if somebody actually knew)?
--mika
Maurice
Posts 108
Maurice replied on Thu, Sep 11 2014 9:08 AM
Yes thinking on its possibly akin to clocking a speedo on a car " moral is think before you type I guess" thanks for the reply though. Regards Maurice
Page 1 of 1 (3 items) | RSS
