double post deleted
BeoNut since '75
mjmedlo: http://youtu.be/gbo3mQFAjE0 Good things are coming soon. Notice the app and onscreen menu!
Also this configuration / set-up demo http://www.youtube.com/watch?v=BG3oxHjwcFg
mjmedlo:http://youtu.be/gbo3mQFAjE0 Good things are coming soon. Notice the app and onscreen menu!
lano:The onscreen meny looks greate! Is it confirmed for what TV models it will work (it was mentioned earlier that it would also work for ML products)? Bsys3?
Photos of B&O display at CEDIA
I tried to post a photo of their display but it is not showing up?
Razlaw:Is there a list anywhere of what systems/items it will work with?
expoman:I tried to post a photo of their display but it is not showing up?
expoman: I tried to post a photo of their display but it is not showing up?
Depends how you do it.
I find this the easiest:
place the photos on your desktop - number them in sequence e.g. 1-show.jpg 2-booth.jpg 3-booth-girl.jpg
then open a post or even a new thread
type your text
then look at the top of the post instructions, and see the three tabs ?
| Compose | Options | Preview |
You should be in Compose to type the post
with the cursor at your last line click Options
see "File attachment " and the button below ?
[Add/Update]
click that button
now the pop up window click the next button
[choose file]
now navigate to your operating system's desktop and select the first file and click [choose]
now click [save]
now click [post]
and voila you have text and the first picture
now just repeat - each picture a new post
once you have the rhythm it goes quickly
