Beocenter 2 power failure
lonfred
Posts 200
lonfred Posted: Fri, Sep 12 2014 10:07 AM
I have a Beocenter 2 that I bought 2006 and that always has worked like a charm.
The last two weeks it has been disconected from power. Yesterday when I reconnected it I got problem with the power. The red dot is shining and everything works fine in about 15-50 minutes, then suddenly the red dot goes out and it stops to work. When I disconnect and reconnect the power again, it starts to work directly but only for 15-50 minutes. Is this a common fault? Is there a battery or something else that has been old and that I need to change?
Thank you in advance!
berlin2010
Posts 92
berlin2010 replied on Fri, Sep 12 2014 11:29 AM
Probably just needs you to enter the pin code - if the unit was not powered for a sufficient period of time it will require a pin code.
lonfred
Posts 200
lonfred replied on Fri, Sep 12 2014 12:04 PM
Unfortunately not that easy. It takes the pin code but then after a while it get black and stop working.
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 12 2014 1:11 PM
Is the socket set in an open position or the right way up so that it is well ventilated?  Is it overheating?
Can you deactivate the PIN when it is working?  Will it now stay on?
Can you put it in service mode? i.e. when a PIN is asked for press the double left arrows 3 times to get to the 'Master PIN setting' and enter '11111'.
Sounds like some sort of thermal protection issue possibly.
Dave.
lonfred
Posts 200
lonfred replied on Fri, Sep 12 2014 8:06 PM
Now it has been working for a couple of hours, perhaps self-healed. For each time when I unconnected and reconnected the power it increased the working time. Perhaps something that needed to load up.
Thanks for your help!
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 12 2014 9:31 PM
Possibly a loose connection somewhere then is most likely. Hopefully it will continue to behave.
Dave.
Page 1 of 1 (6 items) | RSS
