Hi all,
I want to register an old (2001) MKI BeoCom 2 hand set to a BeoLine MKI. I cannot see any options for doing this in the menus. It does not have the advance options menu as the other BC2 I've got. Is there a way to reset it so that I can search for the BeoLine base station?
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Not sure but try 9#9#9*HOLD
Thank you, but I have already tried this. There is no reset option here either, sadly. I called the local B&O dealer and he said that the only solution is SW update. He could not tell me the costs as they had to send it to Struer Does anybody know the costs for this service?
