I currently have my BeoLab 5 speakers hooked up to an Integra DHC-80.3 preamp through the line-out phono jacks. The preamp has a rated output voltage of 1 V into 470 ohms with a maximum output voltage of 5.5 V into 470 ohms through the phono jacks.
I'm considering switching to a Powerlink plug with RCA input and 1/8" trigger at the speakers so the preamp will turn on the speakers via the trigger line. I hope to be doing this with the surround and center speakers as well when I get them.
I believe the trigger line is to have a input voltage of 4.7 V.
What is the permissible input signal voltage for the BeoLab 5? I don't want to "blow out" the input circuitry of these speakers.
D
Doonesbury: What is the permissible input signal voltage for the BeoLab 5? I don't want to "blow out" the input circuitry of these speakers.
The maximum input on a Power Link input is 6.5 V rms if it's a sine wave. This translates to 9.19 V peak.
However, if you're going to use the Power Link input on a BeoLab 5, you will also need to send it Power Link data so the loudspeaker knows the volume setting of the source. I honestly don't know what will happen if you try to use the Power Link input without Power Link Data.
Maybe one of the others on the list knows this. Steve - any idea?
If not, I'll ask around at work to see if I can find out the answer to this one.
Cheers
- geoff
Geoff Martin: Doonesbury: What is the permissible input signal voltage for the BeoLab 5? I don't want to "blow out" the input circuitry of these speakers. Hi, The maximum input on a Power Link input is 6.5 V rms if it's a sine wave. This translates to 9.19 V peak. However, if you're going to use the Power Link input on a BeoLab 5, you will also need to send it Power Link data so the loudspeaker knows the volume setting of the source. I honestly don't know what will happen if you try to use the Power Link input without Power Link Data. Maybe one of the others on the list knows this. Steve - any idea? If not, I'll ask around at work to see if I can find out the answer to this one. Cheers - geoff
I'm hardly a B & O audio expert, but your reply makes it sound like the audio levels into the BeoLab 5 are to be constant, with audio levels within the BL5 adjusted by another signal in the Power Link connection. Is this correct?
If so how is one to use B & O speakers with a non-B & O preamp?
Doonesbury: I'm hardly a B & O audio expert, but your reply makes it sound like the audio levels into the BeoLab 5 are to be constant, with audio levels within the BL5 adjusted by another signal in the Power Link connection. Is this correct? If so how is one to use B & O speakers with a non-B & O preamp?
That would be a logical, but partially correct assumption to make.
If you use the RCA Line input, then you can
If you use the S/P-DIF input, then you can
If you use the Power Link input, then
In the Power Link input case, the gain is actually changed in the source (the B&O Master), however, the signal-to-noise ratio of the BeoLab 5 is optimised for that volume setting using the Power Link Data input.
If you do not have Power Link Data coming in the Power Link input, you will get no sound.
You cannot use the RCA Line input and turn on the loudspeaker using a 5 V DC trigger on the Power Link input via a second cable. (we just tried this because no one here knew whether this would work or not...)
Note, however, that if your goal is to optimise your BeoLab 5 input for a line signal that is higher-than-normal, then you can change the maximum allowable input voltage of the RCA Line input from 2.0 V rms (the default) to 4.0 V rms.
-geoff
Løsningen er at logge den datastrøm et b&o produkt smider ud under opstart og skrive en stump kode til en PIC (microprocessor), så den optræder som et b&o produkt.
Click here. - Sorry only in Danish.
/ Peter Pan
