Beovox 3702 Repair Midrange speakers scrapping
This post has 6 Replies | 0 Followers
esta
Posts 4
esta Posted: Thu, Sep 18 2014 5:30 PM
Dear members,
I am all new to this forum and have started restoring an old Beocenter 3500. After a few days of fixing the turntable mechanism I am quite pleased to have that repaired and brought back to work.
The beadings of the 8 inch low-range speakers of both my Beovox 3702 were totally scrapped. After replacing them, they are aligned just fine and sound perfectly. But, the midspeakers, that appear to be quite fine if you look at them from the outside,  are both giving a scrappy noise as if they were not aligned well.
The sound does not disappear when I gently move the diaphragm to the different corners of the midrange speaker and voices just sound awful.
What can I do? Is realigning possible on those? With new foam beedings? Or can I replace those two speakers? Or do you know anyone in Denmark or Germany I could have them shipped to for repair?
Any answer is highly appreciated!
kind regards,
Erich from Germany, currently Odense, Denmark!
Søren Mexico
Mexico City
Posts 6,411
Contact Dillen in Copenhagen, and welcome to the forum
esta
Posts 4
esta replied on Thu, Sep 18 2014 5:50 PM
Thank you, I already saw his name (and yours, btw) on other 3702-related posts here.
Søren Mexico
Mexico City
Posts 6,411
Did you check the crossovers, (caps), when pressing gently on the mid range drivers, is there a scraping sound ?.
Before sending the drivers for repair, I would change the caps in the crossovers, and check all other components. And check the wire connections at the drivers,
esta
Posts 4
esta replied on Thu, Sep 18 2014 6:46 PM
Thank you for your fast answer.
I have not seen any crossover so far for I didn't think of it beeing a crossover issue. Actually, the cables look fine near the speakers, I still have to examine them as far as I can and probably at least have a look at the capacitors of the crossover. The problem occurs on (low)medium to higher volumes, preferably on sung voices and sounds best like "grzzz" or whatever... Smile
It occurs on both sides, meaningless of which side or speaker output I connect whichever speaker. I was not able to test it with headphones to opt out on a Beocenter issue, but will do as soon as I managed to obtain an adapter here in Denmark.
Søren Mexico
Mexico City
Posts 6,411
Any chance of testing the speakers with another amp
esta
Posts 4
esta replied on Thu, Sep 18 2014 9:30 PM
No other amplifier here, however, tomorrow I can check the sound at least by headphones. It is really difficult reparing such a thing in a foreign country.
Page 1 of 1 (7 items) | RSS
