BV8 - strange pink splodges on the screen
This post has 9 Replies | 1 Follower
Andrew
Frinton, UK
Posts 917
Andrew Posted: Thu, Sep 18 2014 5:35 PM
Hi
My BV8-32 has only 214 days of video use (I am assuming this is low) but when displaying a white background, like snow, seems to have funny pink splodges on the screen - is this a sign that the screen is on the way out or is there something I can adjust in the service settings?, I have had a look but reluctant to change half the stuff I haven't got a clue about
I seem to recall that it may be dust or something, if so is that easy to fix?
elephant
AU
Posts 8,219
elephant replied on Fri, Sep 19 2014 8:06 AM
If 214 days is actual 1,600+ hours is that high or low ?
I might look up my two for you.
BeoNut since '75
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Sep 19 2014 12:51 PM
Thanks, I thought it was low as my old Avant had well over 500 days and that still had a good picture
The splodges are only really apparent on white backgrounds so not the end of the world but would be useful to know if there is a fix
elephant
AU
Posts 8,219
elephant replied on Sat, Sep 20 2014 8:00 AM
elephant:
took some time to remember how to do this !
BV8-40
  • Audio (days) 16
  • Video (days) 281
  • ON (T*10) 238
  • Total Ontime (hours) 7,165
BV8-32
  • 18
  • 206
  • 390
  • not listed
BeoNut since '75
MartinW
Posts 389
MartinW replied on Sat, Sep 20 2014 6:55 PM
If you're using an HDMI cable, i would try a different cable to see if that cures it. I have seen similar symptoms and HDMI was the cause.
Andrew
Frinton, UK
Posts 917
Andrew replied on Mon, Sep 22 2014 12:40 PM
Ahh, thanks MArtin, yes it's also quite a long cable so will try moving the apple tv box closer to the set and a shorter lead
BenSA
Durban, South Africa
Posts 1,404
BenSA replied on Mon, Sep 22 2014 1:26 PM
I have the same problem with my Beovision 7.
Very odd, have no idea what it is.
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Sep 24 2014 11:14 AM
Hi, doesn't seem to be the cable, read up that most cables should be fine as it is a digital signal so would be really poor if it was defective. I turned up the contrast and that seems to have more less got rid of the problem - BenSA - don't know if that will help with yours? I had to switch off the auto contrast as well as the screen was just too dark. Picture seems much better
Andrew
Frinton, UK
Posts 917
BenSA
Posts 1,404
BenSA replied on Wed, Oct 1 2014 2:28 PM
I also increase my contrast etc ajames and it definitely helped. Luckily it only shows when it is a very pale image showing. Still it would be better not to have those marks.
Page 1 of 1 (10 items) | RSS
