Choosing a mini amp for a pair of S45-2's
PBHansen
Posts 4
PBHansen Posted: Sat, Sep 20 2014 4:13 PM
Hi
I would like to hide away the amp in my setup, and I am looking into using a mini amp for my s45-2 speakers. The speakers will be placed in a decently sized living room. The setup might be somewhat temporary, so I would like to be very cost effective but there is no set budget.
The following amps pop-up when searching the web for affordable mini amps:
lepai lp-2020a+
Topping TP30 or TP10
Is this feasible and can anyone tell my what kind of specifications I should be looking for or with recommendations for a specific amp?
 Thank you for taking the time to look at this
Peter Christensen
North Providence, Rhode Island, USA
Posts 12
You might consider a TI 3116 based amp.  These are very inexpensive, and sound wonderful.  If you search ebay, you should be able to purchase one for around  $40US + the price of a laptop power supply.  Regarding power supplies, it seems a 19.5v version sounds the best (power supplies can rage from 12v to 24v, which changes the power output of the amp accordingly).   At 19.5v, the little amp will put out about 33 watts, which is ideal for your S-45-2's.  This amp will top out at 50 watts at 4 ohms with a 24v power supply.
Good luck!
Pete
Page 1 of 1 (2 items) | RSS
