I have a BV11 on a motorised hinge.
Usually, on first turning on the TV, the screen moves gently to its usual position (around 40 degrees) during which time the Bang &Olufsen logo appears. The curtains open some seconds after the screen has stopped moving.
However, on two separate occasions the screen has moved very slowly, and the curtains have opened long before the screen has reached its viewing position. I have checked the cabling where it enters the TV and nothing could be interfering with the hinge. Do random slow hinge openings suggest a motor problem? (Switching on and off after one of these 'Slow' starts moves the screen back to the wall and out again at normal speeds).
Graham
Interesting.
I will get my BV11 on motorised hinge delivered Wednesday next week. Will ask the technicians if they have heard that problem.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Interesting. I will get my BV11 on motorised hinge delivered Wednesday next week. Will ask the technicians if they have heard that problem.
Thanks.
I've had no further repeat, but it would be interesting to know whether it was likely to be a software caused problem rather than a mechanical/ electrical issue.
Hi Graham
We have had numerous motorised wall brackets fitted in the showroom since BeoVision 11 was launched and I can't recall ever having a problem with one.
Given the complexity of the software and frequency of updates, my best guess is that your incident may be software related rather than the motor itself.
Keep me informed if you have further concerns and we will arrange an inspection.
Regards
Opman
p.s. Sorry I missed you the other week.
Opman: Hi Graham We have had numerous motorised wall brackets fitted in the showroom since BeoVision 11 was launched and I can't recall ever having a problem with one. Given the complexity of the software and frequency of updates, my best guess is that your incident may be software related rather than the motor itself. Keep me informed if you have further concerns and we will arrange an inspection. Regards Opman p.s. Sorry I missed you the other week.
Thanks Nick.
All running OK at the moment...... Hopefully just a software glitch.
Hi Michael,
I will take a look at my files and come back to you.
Michael,
Instructions found and emailed to you.
Original thread on my installation: https://archivedforum2.beoworld.org/forums/t/3788.aspx
