Beo remote shift function
This post has 8 Replies | 0 Followers
vlohjr1
Posts 553
vlohjr1 Posted: Thu, Sep 25 2014 7:18 PM
Would be grateful if anybody know where the shift function is please thanks as I need it for a puc function
Vince
Fl_ip
Posts 160
Fl_ip replied on Thu, Sep 25 2014 7:23 PM
Which function, which tv?
Fl_ip
Posts 160
What decoder?
vlohjr1
Posts 553
vlohjr1 replied on Thu, Sep 25 2014 7:51 PM
B&o wrote a special puc code for me but it requires a shift function on the beo remote 1 which I can't locate
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Sep 25 2014 8:19 PM
Which button combination did you have to use on the BEO4 to do what you want?  There is a document to tell you the equivlent on the Beoremote one which may help.
Don't you just need to be in the TV mode and use 'List' and then find the 'Shift' submenu and change the 'show/hide' feature?
Dave.
vlohjr1
Posts 553
vlohjr1 replied on Thu, Sep 25 2014 8:29 PM
Sorry Dave its the for the new beo remote 1 the control function is 'shift' + 9
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Sep 25 2014 9:28 PM
Yes, I know, but can't you find the 'shift' function as I described on the BeoRemote1?  The user manual for the remote describes the 'show/hide' function for any source i.e. TV, music etc  on page 9.
If you answered the other questions you've been asked, someone may be able to help you.
Are you trying to control a 'BEO4' product? i.e. not the New Avant. - page 16 of ther user manual for the BeoRemote1.  If you are and you select a 'BEO4' product, the appropriate list will be on the BeoRemote1.  That should include 'Shift'.
Can you not just contact the B&O dealer who set this up for you?
Dave.
Fl_ip
Posts 160
Fl_ip replied on Thu, Sep 25 2014 9:58 PM
Shift + 9 is power toggle.With the new Avant the option is in the menu
vlohjr1
Posts 553
vlohjr1 replied on Thu, Sep 25 2014 10:20 PM
Sorry Dave bit confused here it's for the new avant and never used beo4 for this puc code its used to control a set top box I tried list and standby but it doesn't work thanks
Page 1 of 1 (9 items) | RSS
