Hello everybody.
I have bought a pair of beolab 1. I think that one of the speaker units are not playing. It a the tweeter unit. Hope you can understand.
But I cant find out how to take the front "grill"?? of the speaker.
anybody who can help me??
with friendly regards
Mr. Kim Agerholm
Denmark
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Welcome to Beoworld.
If you lie the speaker on it's back on something soft to support it, as has been said, there is a release mechanism at the top. Put your fingers into the recess.
1. Push the release mechanism.
2. Slide the front frame upwards towards the top of the speaker by about 10cm.
3. Lift the front frame away.
Remove the 2 screws and slide off the front cover.
You should also be able to do this upright.
Dave.
Thanks alot.
It wasent tweeter. dont really know what it is.
it sounds like the middle speaker is playing a little bit louder and cleare in the left speaker.
Strange. i must do some more testing.
KIm
Dave Farr:Welcome to Beoworld. If you lie the speaker on it's back on something soft to support it, as has been said, there is a release mechanism at the top. Put your fingers into the recess. 1. Push the release mechanism. 2. Slide the front frame upwards towards the top of the speaker by about 10cm. 3. Lift the front frame away. Remove the 2 screws and slide off the front cover. You should also be able to do this upright. Dave.
