I would like to use my BM5000 as a pre-amp, but I need to buy a 4002 switch unit, this it seems is nothing more than a 12v trigger
The 4002 is triggered by the power on the 5000 so you can power on a dedicated amplifier at the same time.
Before I figure out how to make a 12v trigger on, does anyone has a 4002 they don't need, or indeed has anyone made something similar to the 4002 switch, I'm thinking it could be within my simple DIY soldering skills, thanks if you can help me on any of this.
