Hi All,
I recently obtained (independently) a Beosound 9000 Mk I and a pair of Beolab 4500. I am wondering if I can connect the Beolabs to the Beosound via Powerlink, and what the right version of cables might be. Any input would be greatly appreciated! Thanks in advance!
Rudy
http://beolover.blogspot.com
http://beolover.com
Are they Beolabs ou Beovox?
Beolab (sorry for the initial "Beovox" posting). With amplifier.
Use Mark II fully wired power link cables if you need the display to be shown.
Thanks!! Like these?:
http://www.ebay.com/itm/New-Bang-Olufsen-Powerlink-Mark-II-8-Pin-cable-speaker-Beosound-2500-3000-3500-/150806011711?pt=US_Audio_Cables_Adapters&hash=item231cbd1f3f#ht_3941wt_1043
They should do the job.
Obviously you will require a pair (2) of cables
Regards Graham
