Questions about Beoplay V1 and connections
This post has 2 Replies | 3 Followers
madskp
Denmark
Posts 321
madskp Posted: Sun, May 13 2012 1:14 PM
I am considering replacing my BV8 40 with the new Beoplay V1 40 but i have a few questions that I can't seem to find the answers on from the official sources:
1) What is the depth og the stand for placing it on a cabinet or a table. I don't wan't it to get to close to the edge so this is essential.
2) I have a surround setup today with powerlink cabling. Are there adapters available to go from the RJ45 connectors on the TV to powerlink or do i have to buy new cables?
3) Today I have af Cona subwoofer powered by af MCL2P connected to the BV8 and this is working fine. This is connected with an MK2 powerlink cable (see this thread http://archivedforum2.beoworld.org/forums/p/1129/9481.aspx#9481 ). The question is will the Beoplay V1 with the new RJ45 powerlink connections (wich I guess is not MK2) be able to power up the MCL2P?
4) I have a Wii connected to the BV8 for now. The Beoplay V1 has an analogue input. In the datasheet http://www.beoplay.com/layouts/SBV-Custom/HMProductPage/BeoplayV1TechSpecs.html   this is described as a mini AV input. Does anyone know if this is a special connector or if there is an adapter included with the TV?
Thanks in advance
Magnus
Norway
Posts 331
Magnus replied on Sun, May 13 2012 2:18 PM
Hi again!
madskp:
Not sure what sort of adapters they offer. But, in any case, if you have hidden your cables or something you could always just buy short RJ45-DIN cables and then use a DIN female-female adapter (third from the top HERE). But I'm sure Steve (from SoundsHeavenly) can make adapters if you wish.
madskp:
A RJ-45 connector has 8 pins, so I see no reason why it shouldn't work with the MCL2P. I'm willing to bet it will work like a charm!
madskp:
It doesn't look like a standard connector to me, so you'll have to buy a B&O adaptor (to SCART, I guess).
Hero71
Posts 79
Hero71 replied on Sun, May 27 2012 9:35 AM
1) 25cm
2) I had my cables replaced but I understand that adapters will become available shortly as well
3) not an adapter
Page 1 of 1 (3 items) | RSS
