I just bought a BEOSOUND 9000 CD CHANGER HOW DO I CONNECT I TO AN AV RECIEVER? I JUST WANT TO USE IT AS CD player in my setup
If your TV is NOT a Beovision Tv just et a cable from your existing equipments CD, TAPE or AUX connection to 5-Pin DIN connector for the BS9000.
If you own a BnO TV with masterlink connection just connect the BS9000 with a masterlink Cable to the TV set.
Ralph-Marcus
The BS9000 has a digital coax output/S/PDIF.
