Someone used my record player and turned it off before the needle came off the record. So, this morning i went to turn it on but the button to start the table to spin isn't working. It's as if it is already pressed down and I cannot push it back up? The button seems stuck?
I don't think it turned off previously which is why the button is still 'down'. Is there a way I can fix this?? I have tried pressing the different speed on the other side of it but it doesn't make a difference, nothing changes..
thank you!!
Hello,
First post ? You don't say hello?
Welcome nonetheless
Turn the platter gently by hand...
Jacques
Yes, lift the tonearm gently by hand, place it at the lead-out grooves and then rotate the platterby hand to let it run through its end-of record sequence.
Thank you so much! it worked :D
Good!
Without pics it didnt happen, but nice to know that it worked, and welcome to the forum.
