I have the two connected via Masterlink.
I have difficulties to get the Beomaster into option 0.
Can anyone with a BM5500 see if it shows the 0 after pressing r"red button">sound>0>store?
It shows the number 1 and the number 2 when i set in into these options. But when I try with option 0, the red light just blinks.
No it doesn't. You need a 6500 or 7000 to do this.
Peter
What would be the best option setting to use the two together?
