Boesound 7007
milanoli
Posts 18
milanoli Posted: Fri, Oct 10 2014 11:49 AM
Hi, I would like to connect my iphone to my stereo via a Bluetooth audio receiver. I have done this in the past with my Beosound 7000 and the Audio DIN line in on the front of the set. On the 7007 this is positioned at the rear. However the 7007 seems to be only able to function normally when the supplied grey DIN plug is inserted into this line in. If i remove this plug and insert my audio receiver this works but the rest of the sets functionality does not produce sound.....is it really one or the other? Is there a way round this? A DIN splitter perhaps to plug them both in simultaneously?
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Oct 10 2014 11:59 AM
Hi, I think the plug you are referring too is if you have a graphic equaliser in between the amp and preamp. So unplugging it removes the preamp and all other sources - what you need to do is connect to the TAPE2 IN phono sockets - i.e 2 x phono plugs to one mini jack. these are under the same flap
Bojsa
Posts 2
Bojsa replied on Tue, May 19 2020 1:28 PM
Hello Andrew, as it seems you have the Beocenter 7007, do you know if the rear DIN line-in connection works through the internal pre-amp/amp? I would like to connect the Beogram 4002 record player to my Beocenter 7007 and use it instead of the default record player.  Please advise.
Page 1 of 1 (3 items) | RSS
