Dear readers!
Unfortunately i don´t now how to fix this issue. So i want to kindly ask you all for your help:
When i switch the tv-channels - always after ca. 1 sec. - the Beovision 8-26 changes the format to "format 2".
In the evening the flickering (during the automatic format-change) is quite unpleasent.
Does anybody know how to set "format 2" as the standard-format?
My goal is to avoid the automatic change every time i change the tv-channel.
Thanks a lot in advance!!!
Peter
