Beolab 7-1, 7-2 or 7-6 embedded in the wall?
This post has 20 Replies | 1 Follower
David
UK
Posts 24
David Posted: Mon, Oct 13 2014 3:20 PM
hi all,
looking to complete a home cinema setup and just debating putting the centre speaker (mine is a 7-6 but presume same concept / issues for the other 7-x speakers) IN a partition wall.
the front grille would effectively be mounted flush with the wall just beneath the TV, with the rear jutting into the media room behind the lounge where the sky box, amplifiers etc etc are all hidden away nicely (controlled via lintronic electronics)
anyone done similar ? Do i need to isolate the speaker from the wall (stud frame with plasterboard partition) or is it best closely coupled / damped etc ?
seems daft i have a nice flush to the wall TV then a centre speak sticking out 20cms plus mounting bracket, means it sticks out best part of 30cm
all suggestions / comments greatly received, thanks, David
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Oct 13 2014 4:33 PM
The only thing I'd worry about with an active speaker is cooling when embedded in the wall.
Jeff
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Oct 13 2014 5:06 PM
Jeff:
That and the bass response.  Also, future access.
Dave.
David
UK
Posts 24
David replied on Mon, Oct 13 2014 6:27 PM
Thanks Jeff, yes fair point, but i think i've worked the cooling side out as the stud wall will have vents higher up to cover this and the wall will be relatively thin (10cm) so only half of the speaker is enclosed and the back still sticks out a bit.
the mounting braket will be bit of a custom affair to hold it to the back of the wall inside the media room (this is a self contained room, north facing against side of the house so is ventilated and contains all the AV and IT equipment for the house, so does not need to be pretty and can be purely functional)
should i have it "free floating" or fixed to the inside of the wall ?
David
David
UK
Posts 24
David replied on Mon, Oct 13 2014 6:35 PM
Hi Dave
acess should be OK as above but the bass response is a worry for me!
Its a leap of faith as i can't easily test this, as once the hole is cut its done ! (Yes i know a good plasterer would make it invisible)
if i mount it to the wall will it make the wall vibrate with it? if its free floating will it rattle against the wall ?
im hoping with it being a centre which is mainly dialogue there is not tonnes of low frequency high volume sounds being oushed out, and i ncan wtweek the soind going to it to accomodate this a little, but the. I lose the quality / realistic sound
anyone done this or similar?
i know there are in wall speakers (including the b&o ones) but these have been designed to work this way whereas im trying to make a free standing one work in an enclosure so really breaking the design principles, but wondering if a small comprisie in quality will give the benefit in the aesthetics im after?
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Tue, Oct 14 2014 12:01 AM
The other issue is the sound from the two drivers underneath the speaker. If the speaker is flush to the wall, you will effectively lose half of your sound!
x:________________________
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Oct 14 2014 2:33 AM
Jonathan:
Probably not half but some. Depends on where the crossover is to the front speakers, I am not familiar with the Beolabs in question. Might be able to compensate by setting the crossover freq for the surround processor for the center higher.
Jeff
Secondlife
Posts 145
Better use the Beolab 7.4
Geoff Martin
Struer, Denmark
Posts 672
Jonathan:
Not to mention the ports on the rear...
Cheers
-geoff
Millemissen
Flensborg, Denmark
Posts 14,680
Nice sound in 'the media room behind the lounge' then Whistle
Jonathan
Posts 1,811
Jonathan replied on Tue, Oct 14 2014 11:47 AM
Jeff:
Jonathan:
There are two drivers on the underside of the cabinet halfway between the front and back. If the speaker was flush mounted in the wall, these drivers would be behind the wall.
olvisab
Posts 1,391
olvisab replied on Tue, Oct 14 2014 11:57 AM
Millemissen:
Nice sound in ' the media room behind the lounge' then
That's how a nerd listening room should look like.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
David
UK
Posts 24
David replied on Tue, Oct 14 2014 1:13 PM
Ah, interesting.
no ports or anything round the back ?
i can probaby " recess" this in,even easier.
thansk will go and do some investigation.
(anoyone want to buy a beloab 7-6 lol )
David
UK
Posts 24
Ah, interesting.
David
UK
Posts 24
Ah, interesting.
David
UK
Posts 24
Ah, interesting.
David
UK
Posts 24
David replied on Tue, Oct 14 2014 1:16 PM
Doh ! I forgot about that, just pulled them out of the box snd am currently walking round the house slapping myself"........
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Oct 14 2014 1:17 PM
dpickup:
Ah, interesting.
The 7.4 has nothing at the rear apart from the connections and the mounting plate.  It would actually look quite good recessed into a wall with just he front cover and acoustic lens sticking out.  The rear is flush and vertical.
Dave.
Secondlife
Posts 145
Secondlife replied on Tue, Oct 14 2014 10:51 PM
dpickup:
Ah, interesting.
Can swap your BL7.6 for my BL7.4.
Also consider the BL10. Might be even more fancy.
Millemissen
Flensborg, Denmark
Posts 14,680
@dpickup
Why must you hide the 7-6?
Why not just use it as it is supposed to?
It's a speaker, not a flatscreen.
Secondlife
Posts 145
Secondlife replied on Tue, Oct 14 2014 11:39 PM
Nicely integrated in a wall looks superb!
Page 1 of 1 (21 items) | RSS
