Beosound 9000 scratching back of the CDs
Rivenflush
Gothenburg
Posts 333
Rivenflush Posted: Mon, Oct 13 2014 5:26 PM
found out that my recently acquired Beosound 9000 is scratching the back of the CDs when the sled is moving between discs. Everything else works fine though. I have adjusted the position screws according to the manual (table stand, "standing up") and also micro adjusted them to see if I a minor adjustment would do. However, no success as of yet.
In one of threads I have found that the rocker arm (part 9134) in the service manual can be the issue:
http://archivedforum2.beoworld.org/forums/p/9723/84833.aspx
However, before I start to tinkering with it I was wondering if this could be fixed by running the test modes 71 and 73 which to my understanding positions the CD sled etc.? (I guess not but I thought I should ask)
Best regards,
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Oct 16 2014 11:26 AM
Hi Martin,
doing the two tests doesn't repair this fault. You have to replace the rocker arm as you already found out.
Can be done by yourself, did the same at my Beosound 9000 MK1 and it works now flawlessly Big Smile
Ralph-Marcus
leosgonewild
Helsinki, Finland
Posts 2,373
I had the same issue with mine. I played around with different settings on the position screws until I got it right. (the suspension is out of "tune", so just try to find one that works).
Page 1 of 1 (3 items) | RSS
