Hello everybody
I would like to link a beosound 4 and a beocenter 2 (2 different rooms) in order to :
- use the A.MEM (sd card) function in the room where the beoenter 2 is located
- use the dvd function where the beosound 4 is located.
Is it possible from a beo4 ? Do I need a masterlink hub or can I plug the cable directly in the 2 units ?
Thanks in advance for your help
Best regards
oLivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
You cannot do what you want as one unit has to be the master and the other, a slave. This means you could , for instance, listen to the DVD on the BS4 if the BC2 was the master, but you could not use the SD card on the BC2. You will need to set the options but this aside, no problems.
Peter
Hi Peter,
Thanks for your fast answer, as usual :)
If I have quite understood, I can use the A.MEM function if the beocenter 2 is the master and the beosound 4 is the slave.
How can I set this option ? Is it explained on beotech ?
If this is done, I just have to press A.MEM (or A.tape) on the beo4 in front of the beocenter 2 ?
What kind of information will appear on the display of the beocenter 2 (title of tracks for example) ?
