I used to be able to set my Beo4 to "A.DVD" to connect my MacMini and get only audio and no video. For some reasons, I had to remap my MacMini to "DTV" and unfortunately there is no "a.DVD" available. Am I overlooking it or does it eally not exist?
If not, is there any other way that I can get audio-only from the Mini mapped to DTV?
The change from "DVD" to "DTV" was necessary as there was no other way to get the PUC running. So now with "DTV", the PUC works, but there is no option availabe for audio-only.
Thanks in advance for your help!!!
You should be able to get audio only by adding "P MUTE" to the Beo4 and then after selecting DTV call up P MUTE from the list and press GO.
Ron
