Hi,I have a SSD-drive (Samsung 840 Pro) connected via a USB-adapter in my Avant and it has worked well. However, the TV will re-partition the drive with a formatting that is not readable from a Windows or Mac-computer so you can't continue using the drive for other uses than TV recordings. On my TV there was no problems at all having the drive converted by the TV. Perhaps there is a problem with the translation to dutch? Kind regards,Michael
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hm, I dont remember how I set it up and my new Avant is currently still in its packaging box. I´ll try to setup a new disk as soon as it is up and running and see how I proceeded. I think I had to do something in the setitngs menu. I use mine in Swedish so it should of course work in dutch to but it could be a bug in the translation, who knows :).
