Hello
i suppose that the question have been still asked but i don't find it on the forum...so please let me know how to connect a pair of Beolab 2500 model 6201 with a preamp which have rca output ; i have try several combination with a link 5 pin din/rca but without any result , the led stay red and and there is no sound even not a hum or strange noise.
thanks a lot for any answer
You need a 5V Power_On Signal on pin 1 or it will not switch on.
http://www.google.de/imgres?imgurl=http%3A%2F%2Fwww.beophile.com%2Fwp-content%2Fproduits%2Fpowerlink_pins.jpg&imgrefurl=http%3A%2F%2Fbeophile.com%2F%3Fpage_id%3D13249&h=641&w=700&tbnid=pW0BPEhLLZDAiM%3A&zoom=1&docid=rqQK4AgGNwyaTM&ei=2pJGVKmhGofWygO4l4GoCw&tbm=isch&iact=rc&uact=3&dur=1402&page=1&start=0&ndsp=57&ved=0CCIQrQMwAA
i have seen on the web a connection diagram with a 5v supply but i didn't think that i was concerned too.so i'll try it thanks for the answer
if the pre-amp has a trigger output you can use this cable:
http://www.av-connection.com/?PGr=1760 (there is also a USB instead of the 3.5mm version)
Else you can buy a combination of cables from Steve:
http://www.soundsheavenly.co.uk/bando-ipodlab2.htm
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
hello thanks to all, it works fine
