I do not appear to have the Edit Function so that I can correct my splung mistuks!
garethingram1: I do not appear to have the Edit Function so that I can correct my splung mistuks!
I did have edit in the drop down box but it's gone tonight!!
Regards Graham
joeyboygolf: garethingram1: I do not appear to have the Edit Function so that I can correct my splung mistuks! I did have edit in the drop down box but it's gone tonight!!
Yep, still gone.
Try to click on the "more" button. the edit option should appear here.
hfat
hfat: Try to click on the "more" button. the edit option should appear here. hfat
I know it should and it did the other day but it's not there now!
not there for me either!
just 10 minutes ago I used the edit function
hfat:just 10 minutes ago I used the edit function
In the Beo5/6 forum it's still available
Nick: not there for me either!
same here.... edit function seems to be out of order tonight
"The first thing we do, let's kill all the lawyers."
William Shakespeare, Henry VI, Part 2, Act 4
Testing Edit
I have edited this..
Regards
Edit function is back... at least for the moment
I hope the glitch is solved
Foxtrott
Gentlemen,
The EDIT issue on the General forum is resolved and I just need to check the other forums.
The issue is one of correctly setting the permissions which is a complex inter-connecting set of permissions between various directories.
Regards Keith....
Thank you Keith!
Edit test.
EDIT
Passes edit test.
I believe that all outstanding EDIT issues are now resolved
