CMOS Battery of Beomedia 1
This post has 2 Replies | 2 Followers
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Wed, May 16 2012 4:45 PM
Dear all,
My BM1 forgets it CMOS settings after a power supply break. I think (hope) the Battery is empty. Does anyone know the type of battery. I would like to by before I open the BM1.
Heirbert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Michael
Sweden
Posts 2,578
Michael replied on Wed, May 16 2012 6:34 PM
I think it is the same as any other pc (usually).  Probably cr2032 since it is a pc :)
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Wed, May 16 2012 9:04 PM
Yes correct, it's a CR2032 and it is located under the pcmcia slot, which has to be removed completely before you can reach the battery, but I think it's only two or three screws.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
