Beolab 4 settings
bramble
Posts 397
bramble Posted: Sat, Oct 25 2014 6:06 PM
I have just got myself a fab pair of beolab 4's, and they sound really good
Problem I have is they have a setting switch wit 1,2,3. Which setting is for what
I also had an issue were I connected them to my pre wired set up and got an annoying buzzing from both spks, then used the supplied powerlink cables and it was fine
Q. Is that cause they are Ice type speakersGeekedGeeked
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
elephant
AU
Posts 8,219
I am not an EE so I can;t explain difference, however I had the same issue until I swapped the power link cables.  They need to be Mark III cables which are distinguished by a small black triangle embossed on the plastic sleeve at each end of the cable.
This is described in the manual as well as the positioning switch -- you can download the whole manual (and any others) from Beoworld if you pay the very modest annual subscription (one time fee if you chose not to renew !),
As the Beolab 4 manual has 3 whole pages on the positioning of these speakers and the use of switch you might find the annual fee worth while if you plan for example ceiling mounts.
However here is the key diagram - you may to abuse the switch to give yourself difference bass behaviours ...
BeoNut since '75
bramble
Posts 397
bramble replied on Sat, Oct 25 2014 7:23 PM
Many thanks , elephant
The latest arrivals!!
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 26 2014 12:31 AM
Nice !!
Deserves to be in the "FLASH your B&O" thread
BeoNut since '75
elephant
AU
Posts 8,219
Nice !!
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
Nice BL4s
White on the front. Blue on the sides.
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 26 2014 11:23 AM
Brilliant idea Michael
I hadn't thought of that !
BeoNut since '75
Page 1 of 1 (7 items) | RSS
