Thanks to forum member Jonathan I was able to get my speaker grills off of my system. Has anybody had any luck getting rid of wrinkles in the cloth? Do these even come apart further? I have the blue speaker grills and would like to keep the system all original.
Thank you
BillWojo
This thread may help if you want to replace them with newer metal ones: http://archivedforum2.beoworld.org/forums/p/3566/32210.aspx#32210
(Leslie's the expert at recovering speaker frets!)
Alternatively, maybe purchase new ones here: http://www.ebay.de/itm/B-O-Paar-Front-Cover-Blenden-fur-BeoLab-2500-Lautsprecher-/271649590342?pt=DE_Lautsprecher_Martin&hash=item3f3f93cc46
(EDIT: But I think the eBay item is just for one!) Cancel that - there's two in the picture!
Yes, I saw Leslie's post, very nice job. I don't have that style fret's though, I have the old flat ones. Hmmmm, I think I can still do it the same way though, material just needs to be about the same thickness. Mine are blue, I kind of like that, need to stop into a fabric store. Thanks for getting me on track. As far as ebay goes, I buy from there all the time but I don't know if the seller is willing to ship to the states. Let me try fixing mine first.
Thanks again
Here is some grill cloth US Ebay
