Spotify connect player for BS5
This post has 121 Replies | 8 Followers
Duels
England
Posts 2,553
Duels replied on Fri, Apr 28 2017 1:42 PM
My dealer advised today that B&O have confirmed that Spotify will not be available on BS5 from May.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Apr 28 2017 1:49 PM
Maybe you should untic auto update
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Duels
England
Posts 2,553
Duels replied on Fri, Apr 28 2017 2:17 PM
gysse2004:
Peter
But too late unfortunately as Spotify isn't currently working. Without playlists it's a very limp feature for me personally in any event.
Time to think about a moment or essence.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Apr 28 2017 2:35 PM
What is your current software? Mine is 7.04.01.1945 - firmware 1.38a
Peter
Duels
England
Posts 2,553
Duels replied on Fri, Apr 28 2017 3:11 PM
gysse2004:
Peter
Thanks. I'll check when I'm home this weekend.
beolion
Posts 485
beolion replied on Sat, Apr 29 2017 4:49 AM
Auto update disabled Indifferent
peterafox
Posts 34
So I had a look at the Behringer UCA222 (about $60 so not too bad).  But I don't understand how you connect, say a Chromecast Audio to it... there appears to only be RCA audio inputs on the UCA222, so do I then need to use a headphone to RCA converter to attach a Chromecast Audio to the Behringer UCA222?
Has anyone setup up a workable Spotify Connect solution directly to BeoMaster 5?  Keen to hear some specifics.
Many thanks in advance.
Duels
England
Posts 2,553
Duels replied on Wed, May 3 2017 9:06 AM
I asked the same question of Steve at Sounds Heavenly.  I am sure he wont mind me sharing his reply and links.
"Thanks for your enquiry, first you need the USB adapter to connect to the Beomaster 5:-
http://soundsheavenly.com/input/17--ufo202-.html?search_query=usb&results=2
This cable will connect the Chromecast Audio to the USB adapter above (a 1m Chromecast cable can be supplied free of charge with the USB adapter on request - please ask for this when you order the USB adapter):-
http://soundsheavenly.com/hifi-av/112--trs-2rca-.html"
Duels
England
Posts 2,553
Duels replied on Wed, May 3 2017 9:20 AM
gysse2004:
Peter
Done that now.
gysse2004
Hellerup
Posts 192
@Duels- is your system back up and running?
Peter
Duels
England
Posts 2,553
Duels replied on Wed, May 3 2017 9:49 AM
gysse2004:
Peter
Yes it is other than playlists.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, May 3 2017 10:17 AM
Spotify is stll running on my BS5, also with new playlists....
Stefan
beolion
Posts 485
beolion replied on Wed, May 3 2017 10:21 AM
peterafox:
I have a Chromecast Audio connected to the UCA222.
I do also have Spotify Connect installed.
Both works fine for me.
A.AUX is used to activate either of them, however, if music is played on the installed Connect, the Connect music will continue if you switch to ie Radio (double input signals) unless you stop the Connect music first. That is not the case when using the Chromecast.
Duels
England
Posts 2,553
Duels replied on Wed, May 3 2017 12:08 PM
stefan:
Stefan
What do you mean by " new playlists"?
stefan
Posts 2,920
stefan replied on Wed, May 3 2017 2:21 PM
I created two new playlists last weekend with John Mayer songs - btw he`s in Herning, Danmark on Friday and I`ll be there too ! (somebody else?) - on my ipad, and they appear also on my BS5...
Stefan
beojeff
USA
Posts 2,012
beojeff replied on Wed, May 3 2017 4:09 PM
The search function on mine is now working again.
peterafox
Posts 34
peterafox replied on Wed, May 3 2017 11:17 PM
Thanks Beolion!
A few questions... How do you connect the Chromecast Audio to the UCA222?
And when using Chromecast do you get any cover art on the BS5 or just the A.AUX input text?
Duels
England
Posts 2,553
Duels replied on Thu, May 4 2017 7:24 AM
peterafox:
Thanks Beolion!
I posted an answer to this with a link for the appropriate cable after you asked your question yesterday.
beolion
Posts 485
beolion replied on Fri, May 5 2017 3:20 AM
peterafox:
Thanks Beolion!
How do you connect the Chromecast Audio to the UCA222?: By using a 3.5mm MALE TO 2 RCA MALE AUDIO CABLE (check ebay)
When using Chromecast do you get any cover art on the BS5 or just the A.AUX input text? Yes, that is why I really like the BS5 player where you get the covers.
lano
Posts 161
lano replied on Fri, May 5 2017 5:54 AM
How can the BS5 know what's playing on the Chrome cast and show the cover arts if it is only connected with two RCA cables?
beojeff
USA
Posts 2,012
beojeff replied on Sun, May 7 2017 2:15 PM
While Spotify is now working, I'm finding that N.Radio stations are no longer working. This is so frustrating. Is anyone else finding N.Radio stations to be unavailable?
gysse2004
Hellerup
Posts 192
No problem with radio in Denmark.
Peter
nico vercammen
Elversele, Belgium
Posts 174
No problem in Belgium ...
Also spotify is working perfect for the last couple of weeks ... had no problems with playlists or stalling Smile
Still hope they continue the support for Spotify ...
Nico
beojeff
USA
Posts 2,012
beojeff replied on Sun, May 7 2017 8:43 PM
N.Music is now working again in the U.S.
beojeff
USA
Posts 2,012
beojeff replied on Mon, May 8 2017 5:28 PM
Duels:
peterafox:
Thanks Beolion!
I'm curious about adding the Chromecast dongle to my BeoSound 5. Provided that you have your BeoSound 5 source set to AUX, are you able to include the dongle in casting from WITHIN the BeoX App, BeoMusic App, or BeoLink 2 App? I know that adding an NL converter would be the ideal solution, but the ability to include the dongle in chrome casting from within a B&O app would be a nice workaround (provided that one has at least one NL multi-room product).
Millemissen
Flensborg, Denmark
Posts 14,680
beojeff:
You can group a ChromeCast Audio dongle connected to any aux-port (which mean also to the line-in of the BS5) with the ChromeCast part of one or more B&O NL device/s.
You must use Google Home for that.
But that does not turn your BS5 into a NL device and you will still have to activate A.Aux to get sound from the BS5 and to control the volume.
A workaround, yes - but it limits you to the cast feature, and you must deal with 3 control points: the cast-enabled app, the B&O app and the B&O physical remote (alternatively the controls on the BS5).
MJBeo
Netherlands
Posts 270
MJBeo replied on Mon, May 22 2017 9:44 AM
I am always doubting if I should start saving for a second hand BS5. I listen to spotify most of the time, CD's and vinyl. I currently have a setup with playmaker to my BM5500, but I am not too happy with the ipad or iphone as a controller. I'd rather use a steel weel of BS5 or a beo4 remote. However, the spotify on the BS5 appears to have similar functionality to the app on my 1st generation iPad, without the "my music" section with saved albums, but instead only "favourites" and "playlists" and "radio". Is that correct?
The lurking danger is that spotify will abandon these old devices, so buying a BS5 would then not the be a good investment for me. Unless it is possible to hack it to be more future proof?
beolion:
Are you saying you installed something on the BS5 that enables spotify connect? I am pretty sure you did not mean that, but since it is a windows machine it should be possible (I got it working on my Beomedia1, although I did not get the sound output right away and I stopped working on it).
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
Gary Nelson
United Kingdom
Posts 52
Is this a work around?
Bit of a gamble, could trash the whole kit and caboodle..
https://www.ebay.co.uk/itm/B-O-Beosound-5-Spotify-OEM-activation/302615250912?hash=item46754647e0:g:kfsAAOSwvktaZ7Rm
Millemissen
Flensborg, Denmark
Posts 14,680
Was already discussed several times on the forum.
The maker also participated here - in fact he announced the solution here a while ago.
Some users did it/bought it - and seem to be contend.
Lars Alsbjerg
Århus, Denmark
Posts 18
would be nice of him to publish the solution...Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Probably no longer available - or vanished?
Have a look at rhis thread:
https://archivedforum2.beoworld.org/forums/t/26408.aspx?PageIndex=1
beolion
Posts 485
beolion replied on Sun, Oct 7 2018 11:06 PM
Lars Alsbjerg:
I have Spotify installed on BS5 directly and use this for Spotify Connect using A.AUX.
No covers though :-)
ethuijs
Posts 68
ethuijs replied on Mon, Jan 7 2019 5:50 AM
Hi Lars,
does this stil work?
What version did you install?
How did you connect Spotify to A..AUX?
beolion
Posts 485
beolion replied on Tue, Jan 8 2019 8:34 PM
Hi
I have installed Spotify on BM5 and use Spotify connect when using a.aux.
However. If you keep Spotify playing while changing to Radio, you will get both sources out ..... feature ;-)
I will check my Spotify version tomorrow evening.
ethuijs
Posts 68
ethuijs replied on Sat, Jan 12 2019 10:48 PM
I have it working with an old win 32 version of Spotify 0.9.15.27
Took me a wile to find a 32 bit version at a safe download site. They al still in the Spotify forum for as long as they are there.
Link https://community.spotify.com/t5/Desktop-Windows/Install-amp-Launch-Errors-Error-Code-53-Error-Code-17-amp-This/m-p/699012
Running at service menu I get a warning that in the future this system will not be supported for updates. When the BM5 losses power Spotify has to be started again. I gave Spotify auto start at Windows reboot but this seems not enough.
And I have the "feature you mentioned. " If you keep Spotify playing while changing to Radio, you will get both sources out".
But so far I am happy with it. Thanks!.
jhamers
Posts 35
jhamers replied on Fri, Feb 8 2019 7:38 PM
That solution (installing spotify directly on BS5) stopped working for me few days ago, other people have the same?
jhamers
Posts 35
ethuijs
Posts 68
ethuijs replied on Sat, Feb 9 2019 12:30 PM
Same problem here. I have posted a topic on Spotify for this problem.
ethuijs
Posts 68
ethuijs replied on Sun, Feb 10 2019 3:17 PM
No usefull reply from Sptify comunity so far. Spotify still works I discovered. When you start play from the service menu. Music plays when you leave the service menu. Only you can not control Spotify anymore because Spotify Connect stopped working.
ethuijs
Posts 68
ethuijs replied on Fri, Mar 1 2019 8:03 PM
Has anyone tried to install a Chromecast receiver on the Beomaster 5?
https://developers.google.com/cast/docs/caf_receiver/basic
Page 3 of 4 (122 items) < Previous 1 2 3 4 Next > | RSS
