Problem with Cabinet 4066 (motor unit)
This post has 6 Replies | 0 Followers
parasound
Sweden
Posts 69
parasound Posted: Sat, Nov 8 2014 6:15 PM
I have recently bought a 4066 cabinet with motor, but the motor unit only have a round 5-pin connector.
My BV3-32 has a square input-connector. I don't understand it be course underneath it says:
Motor unit BeoVision 3 stand
Type No: 4066
Item No: 1406666
Serial No: 17599397
The motor is located under the cabinet, if it will help.
I would appreciate if someone could help me solve this problem.
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Jason
Redditch Worcestershire
Posts 177
Jason replied on Sat, Nov 8 2014 7:09 PM
For the bv3 you need an adapter plug, I've had one siting on my dash board for ages, pm me your address and I'll pop it in the post for you
regards jason
parasound
Sweden
Posts 69
Hi Jason!
I have send you my address Smile
Jason
Posts 177
Jason replied on Sat, Nov 8 2014 9:54 PM
Just checked and my email is wrong but can't seem to change it, can you pm me instead, I don't want anything for the connector, it will just end up in box hiding bits I am looking for
parasound
Sweden
Posts 69
parasound replied on Tue, Nov 18 2014 8:06 PM
The swedish post office has trouble sometimes!
But now the adapter arrived, and it works fine 😀
Thank you wery much Jason!
parasound
Sweden
Posts 69
Jason
Posts 177
Jason replied on Tue, Nov 18 2014 10:22 PM
Glad to hear it
jason
Page 1 of 1 (7 items) | RSS
