papichullo: I do wish I could use the beo4 remote with the aTV but I am happy everything is still working and I can enjoy my music on my B&o
You should be able to control your ATV1 with the Beo 4 via the STB controller in your TV.
I controlled my ATV1 from my Beo 4 via STB controller in my UK spec BV5 (with scart sockets). You have to plug in an IR emitter and then set the TV correctly in the TV menu. Unfortunately I cannot remember the setting as I now have a Windows Media PC connected, but I think I connected it and set it to V-Aux. However when you have it set up you choose Apple Remote in the BV5 menu (there was a choice of 3 Apple) and I remember choosing Apple Remote as the others did not work. You have to ensure you have no apple remotes "paired" to the ATV and do not "pair" the STB emitter. (it seems pairing any remotes interferes with the BV5 being able to control it. The manual tells you how to unpair all remotes.) .
Hope this helps
Stoobie
