BV4 given up the ghost
Gary Nelson
United Kingdom
Posts 52
Gary Nelson Posted: Thu, Nov 13 2014 8:45 AM
Hi Beoworlders
Looks like my television doesn't want to play any more Sad
When it used to start up you used to hear a couple of clicks and a buzz as it wound up, now when I turn it on it doesn't make any such noise and only the sound comes through the speakers.
So do I bin it or do I replace a board that makes that buzzy noise?
If it is going to that beovision grave yard I'd like to examine the possibility of replacing  the screen with a Panasonic one (the same as the one B&O used in the original BV4) as I suspect this will be the most cost effective solution.
I welcome advice from my cleverer Beoworld buddies out there.
Help!
Gary
Gary Nelson
United Kingdom
Posts 52
Perhaps I need to rephrase my question...
Which model number Panasonic monitor is behind the Beovision 4 Aluminium bezel?
Gary
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Nov 17 2014 5:24 PM
Hi Gary,
There are actually a couple of BV4 "panel-only" auctions on eBay from another 'reseller' (I hate that word for some reason..) who is a reputable chap.
Here's one.. a 50"
and here's a 42"
Lee
Gary Nelson
United Kingdom
Posts 52
Thanks for your help, Lee.
I might end up going down this route, I have to confess I had seen these but recall something on beoworld where the Panasonic panel was replaced in the BV4.  I have also managed to locate this article in the Archive bit.
It appears with some jiggery pokery in the panasonic  menu using the connectors I already have to my BS2 I can use a Panasonic 42 TH-42PWD7 which seem to start at £30 rather than £300 on eBay.
Research tells me moving the B&O bezel onto the 'new' monitor is a swine on account of the number of screws, but if I can get the tele up and running for Christmas I expect less grief from the one that must be obeyed.
Gary
Page 1 of 1 (4 items) | RSS
