Beogram CD4500 spindle problems
This post has 5 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Tue, Nov 18 2014 9:16 PM
Hi
Does anyone have any experience with refurbing the cd-spindle thingy in a cd-player ?
The thing I am talking about is this...
When inserting a cd, it is clear that the motor is spinning some time without the cd, after a second or 2, the cd is up to speed and the player works fine..
Is it possible to change the black stuff on the base so the cd's will have better grip again ? Or other stuff that can be applied ?
Anyone ?
Thanks in advance
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 19 2014 3:43 PM
Sorry for the duplicate post... I thought it was an error on the site when it said it needed to be approved by moderator....
/weebyx
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Nov 19 2014 4:27 PM
What makes you think that is the issue?  On the underside of the lid, there is a spring loaded clamp system.  Is that working properly?  It should feel firm to depress the clamper upwards.  Maybe there is where the problem lies.  The spindle you show looks normal to me.
Dave.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 19 2014 6:35 PM
Dave Farr:
Dave.
Yes, I am 100% sure.. The black stuff is completelly dried out, even if I just put in a CD without closing the lid, then I can spin the CD without the motor is turning also.. The cd is totally loose...
However, I have solved the problem :)
Bought some black "rough" tape about 0,3mm thick at my hardware store, using 2 washers to use as templates and cut the tape with a very sharp knife.. Works like a charm now, no sound what so ever, start and focus is much faster :)
Maybe I will buy 2 washers with more precise size to get it to look a bit more like the original..
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 19 2014 6:48 PM
Dave Farr:
Dave.
And yes, the clamper feels very firm, that was the first thing I tried, I dissasembled it at made sure it was working, and that the spring was very "springy" :)
/Weebyx
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 19 2014 7:38 PM
Very good Jacob! Another thing learned...
Brengen & Ophalen
Page 1 of 1 (6 items) | RSS
