I had Beovision-8 all set up with my PC. But when I press the ' MY PC' button to access it, nothing happened. Still, when I press 'TV' or 'DVD', it worked just fine. Do you think there is something wrong with my BEO4 remote control or just the setting?
The funny thing was I pressed other buttons like the DVD then MENU, trying to work on the settings, and now the DVD button is also not working.
Can anyone help me?
BeoNut since '75
Yes, it is a hotel version I think. It does not have a 'LIST' button, just a menu button.
The set-up should be easier since I wanted too use it as PC monitor alone - cable setting not needed.
HDMI cable was connected. I pressed the pc button ( HDMI => YES setting). It worked the first time, but the next time around, nothing was shown on screen.
I even tried VGA cable in case there was something wrong with my HDMI. Is there a problem with the tv?
