Is it possible to change the battery of an Beocom 5.
Does someone have an manual to do so.
It is possible. But you have to follow the instructions in the service manual. Either your dealer may provide a manual and do the work for you (Otherwise you may be screwed up if you have a pair of left hands and/or don't have some tools mentioned in the manual) or look for the service manual in this site (as a silver or gold member in this forum).
