Hello out there,
Can buy a reasonably priced ML unit for my BV6-22. Is it possible to install this yourself? Or should this be done by a dealer with subsequent costs?
Thankx
MP
its not to bad if u have a bit of confidence, u take the fret off, remove screws, glass and back comes off and then it slides in vertically to the right on the back.
