Hello, i am wondering whether there is an option to select between tone and pulse dialing on the Beocom 5. At the moment it seems that if i open the line and then dial, it uses tone. If i find a number on the call list or in the phone-book, it uses pulse.
The beocom is connected to a beoline PSTN. I just want to get rid of the pulse dialing altogether.
Finally found the solution.
Mode 3In mode 3 both predial and postdial are set toTone (DTMF).> Press **781*3#> Press call and await a dial tone.> Press call to store the setting.
Pontios, you are an absolute legend. I was having an identical issue with my Beocom 2. Have just tried this, and its now using DTMF for phonebook numbers. I am beyond happy.
Thanks again.
Stuart
