Hi folks, I've got a HDMI to SCART coverter from ebay. It works but the picture quality is not very good at all. Does anybody know if it's possible to get one that is lightly to be better? I know the SCART will limit things, but the colours are very washed out.
Thanks, Andrew.
Hi Andrew what are you trying to connect from/to and do you have DVi option ?
It's all very complicated.... I'm connecting a mac mini. It's connected to the main tv via the dvi and works perfectly, the problem comes trying to get the same picture to a link TV. That needs to come through the scart....
