FM Aerial (antenna) connection on Beomaster 6500
Cleviebaby
Exeter, United Kingdom
Posts 672
Cleviebaby Posted: Wed, Nov 26 2014 12:16 PM
Up until now, I have limited the use of my Beosytem 6500 to Records, CDs and the occasional casssette.  Having now decided to part with some of my other systems, I want to use the 6500 for radio as well.
I have an 8 element external FM aerial that gives brilliant reception on my other B&O FM tuner/amplifiers where the aerial connections are relatively straightforward to access, but with the 6500, there's a real problem. How do you get an FM-coaxial plug and its cable into the ridiculously small gap at the bottom corner of the rear of the tuner/amp where the socket is?
Has anyone else had such a problem and how did you overcome it?
Cleve
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Nov 26 2014 12:22 PM
Snap the cable and install a 90° angled plug. Not all of them fit, either, but sometimes leaving the plastic cover off is enough.
EDIT: as seen here
--mika
Cleviebaby
Posts 672
Thanks Mika, particularly as I should have found this myself. I searched the site before posting the question - I can't believe I missed it. Many thanks for such a quick response.
Cleve
Page 1 of 1 (3 items) | RSS
