Hello,
is it ossible to use Beosystem 2 or 3 with a non B&O display, e.g. connect an ordinary Samsung LED?
The reason would be to use it sort of like a receiver for the surround speakers (BL8000 + BL6000)
BR
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
i dont see why not as long as the samsung has a vga input, also you would benefit from getting the hd version of the beosystem 2/3.
I have an opportunity to get a Beosystem 2. Is it really sure that it cn be connected to any non B&O display. Hard to find info about it but saw somewhere that people said that you could only use Panasonic displays.
Does anyone have any experience from this?
Please search on the archived forum....
There are lot of threads.
Ralf
B
Basically any VGA enabled display can be used, but you do need to short a couple of wires on the serial port cable. Once you have done this, you can bring up the menus and set up a stb(V.AUX) to take a second input (like hdmi) from a STB.
