Beolab Penta 3
This post has 8 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Dec 3 2014 6:36 PM
Hello All
I have just collected a not so lovely set of Beolab Penta 3 that need some attention.
The main things are:
  • Feet look a little tired
  • refoam needed in thet next 12 months
  • tops coming off
  • some dents
is there any guides on the repairs?
I can take the electrics out and give to my father to repair :)
Has anyone ever covered the grills in white cloth?
would the speaker be visible through the cloth?
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Mark
London
Posts 1,063
Mark replied on Thu, Dec 4 2014 9:27 AM
great speakers and I'm sure you will enjoy the sound.
the tops are held on by double sided sticky tape, be careful please as the edge of the tops are rather sharp.
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Dec 4 2014 11:18 AM
Mark:
...and if you bend them, you'll never get them straightened again.
I believe there was a thread in the archived forum about white cloth Pentas (good luck searching). Looked pretty good as far as I remember.
--mika
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Dec 4 2014 12:42 PM
tournedos:
Mark:
I just did a Little 'Googling' and here it is:
http://archivedarchivedforum2.beoworld.org/forums/p/38842/328867.aspx
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Fri, Dec 12 2014 10:23 AM
Hi there
This thread was brilliant thank you.
I will start with the following.
1) New fret cloth
2) Amp strip down and check dry solder joints
3) Cross over strip down check components
4) New Feet
5) Find someone to make new metal covers / fix existing.
Any advise would be great
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hello All
I have received my new fret from the USA today so I am ready to send them off to be recovered in Black.
Does anyone have any experience of revamping the feet / bases?
Mine looks like they have come apart at some point and it looks like foil has been torn?
I was thinking about taking them apart and having them sprayed but i am not sure yet.
Any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Dec 29 2014 5:09 PM
To remove the topanel use a heatgun or hairblower. Have patient it will come quite easy without bending.
Brengen & Ophalen
Seanie_230
UK
Posts 2,278
I mean the bottom base.
i know how to take then off but wonder how they can be redone
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Dec 29 2014 7:21 PM
Same thing. Plastic panel on top of the base is fitted with ds tape as well.
Brengen & Ophalen
Page 1 of 1 (9 items) | RSS
