Hi All,
I have just purchased an Avant 55 Television and I adore it. The goal is to replace all my equipment with B&O (I'm looking at you Beolab 18's!), but in the meantime, I have a Sonos Playbar that is just sitting there, so I thought I would try and connect it up to the Avant instead of it going to waste.
So I was just wondering if it would be possible to connect the Avant 55 wirelessly to a Beloab receiver 1 (http://www.beoshop.co.uk/index.php?route=product/product&product_id=189), and use this cable (RJ45 to RCA, http://www.soundsheavenly.co.uk/bando-rj45rca.htm) to a Sonos Connect?
Unless there is a better way?
Michael
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
The main problem (apart that the sound from the Avant is way better than the play bar) is that there will be a huge audio delay, sound will never be synchronized to picture because of the time taken by the ADC converter of the Sonos to convert the input.
diisign.com
